Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   engine work... (https://honda-tech.com/forums/hybrid-engine-swaps-18/engine-work-392086/)
aNothuRgSrCivic Jan 21, 2003 09:21 AM
engine work...
i bought a integra gsr engine and tranny to put in my 97 civic. i called a place and they said that it would cost $1000 to put it in. my civic when i bought it was an auto... https://honda-tech.com/forums/images...s/emthdown.gif is 1000 dollars too much? they said it would take about three days. thanx
poison Jan 21, 2003 09:24 AM
Re: engine work... (aNothuRgSrCivic)
that's way too much for labor only.
For $1000 I would be sure that covers all labor costs, complete installation with no ECU codes of the GSR swap, and all manual tranny conversion parts (ie - hydraulic clutch system, clutch pedal installation, master cylinder, etc.)
aNothuRgSrCivic Jan 21, 2003 09:34 AM
Re: engine work... (poison)
yeah they said that they would provide the clutch and everthing.
aNothuRgSrCivic Jan 21, 2003 09:37 AM
im kinda new to this swapping stuff. what do you mean" with no ECU codes of the engine swap?
ransack Jan 21, 2003 06:04 PM
that when the car is swapped and the auto to manual is done also, that no check engine light comes on. I bad ECU code will make the check engine come on.
Like he said above, make sure that you get it ALL for 1000
//Jesse
