Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   Which ECU (h22 help) (https://honda-tech.com/forums/hybrid-engine-swaps-18/ecu-h22-help-1463029/)
Myh4tch Dec 13, 2005 09:46 PM
I have a obd1 h22 swap in my EG and I know the stock ecu to use would be the p13 but I dont have it and im just using a p28 right now to get around but the thing is I have GSR injectors wired up so should I use a GSR ecu like a p72, will that work good?
2point2 Dec 14, 2005 12:39 AM
Re: Which ECU (Bystander.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bystander. &raquo;</TD></TR><TR><TD CLASS="quote">I have a obd1 h22 swap in my EG and I know the stock ecu to use would be the p13 but I dont have it and im just using a p28 right now to get around but the thing is I have GSR injectors wired up so should I use a GSR ecu like a p72, will that work good?</TD></TR></TABLE>
A p72 will work better but i have seen some nasty dynos from using p72's on H22A's.. H22s appear to be way more thirsty in the mid range from what i remember..
You are perfectly fine with the p28 or p72.. you should do some searching on chipping the p28 and tuning it.. "Crome Pro" sounds like a good and economical option these days.
please do not ruin your H22A by driving it hard on an untuned (stock p28 or p72) ECU. https://honda-tech.com/forums/images/smilies/emthup.gif
good luck.
edit:
ALSO, the p13 uses a resistor box to run the injectors, the p28/p72 do not.
Slopoke Dec 14, 2005 11:29 AM
Re: Which ECU (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
ALSO, the p13 uses a resistor box to run the injectors, the p28/p72 do not.</TD></TR></TABLE>
The injectors determine if a resistor box is needed, not the ecu. So if you running obd1 or obd2A H series injectors, you need a resistor. If your running obd1 or obd2 B series injectors, you dont need it. Regardless of the ecu.
BUT, I would not recommend running an h22 with gsr injectors. The h22 injectors are a different size.
Myh4tch Dec 14, 2005 01:58 PM
Re: Which ECU (Slopoke)
I actually dont drive it right now, its sitting the garage because I dont want to mess anything up, so gsr injectors are not good because they are not big enough? So can I just get a p72 and tune it with vafc or would I have to use hondata?
The_Head Dec 14, 2005 04:03 PM
P72 in red, P13 in blue. H22A motor.
http://www.importreview.com/reviews/H22Aecutest.jpg
I have an OBD-1 JDM P13 ECU for sale
/shameless plug
