ECU error codes, 19 and 20
I have completed a D15B Vtec Swap into my 94 Hatch 5 spd I have used the JDM ECU P08. I have unhooked the purge control solenoid, from what I understand this is not needed when using the JDM p08 ecu with this d15b. The next problem THE CEL is on, So I checked the codes I get code 19 (auto trany lock up control solenoid) and code 20 (electric load detector). Does this mean I have an Auto ECU? and do I get the code 20 because this other auto sensor does not exsist.? if not why this code 20? and does running an auto ECU in a 5 spd car hurt anything? and is there any way to get the CEL off? I know this is a lot of crap to take in, but help would be appreciated.
Re: ECU error codes, 19 and 20 (tiresmoke)
OK the ELD could mean the ECU may need to be replaced. what would cause this to go bad? and is it a problem?
