ECU ERROR CODE QUESTION
I have two error codes...i did a swap from a D16Z6 to a b16a1..now I have not installed my Oxygen Sensor because I need to make a whole for the headers. So with that in mind I have a cel check for 01 (oxygen sensor "A" primary) and cel check 43 (primary oxygen sensor - heater). I know that code 01 is the oxygen sensor not connected but what is 43...i mean i looked it up but what does it really mean?
Re: ECU ERROR CODE QUESTION (incognitoracerr)
part of the heating element in the oxygen senor. just hook up your 02 ...
Re: ECU ERROR CODE QUESTION (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">part of the heating element in the oxygen senor. just hook up your 02 ...</TD></TR></TABLE>
Yup, in a four wire O2 sensor, there is the O2 input, and a powered Heater control which requires the Heater wire (D14 pinout), and the power and ground to that sensor. Just hook up the O2 sensor.. |
| All times are GMT -8. The time now is 03:14 AM. |
