Ect sensor problem
I just finished a jdm h22 swap into a 93 del sol, and my ecu is throwing a ect code (6). Does anyone know what the pinout on the ecu is for the ect. I'm running a chipped obd1 p28. I just wanted to make sure it is wired right before I go out and buy the sensor, this swap drained my wallet.
Re: Ect sensor problem (93delslo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93delslo »</TD></TR><TR><TD CLASS="quote">I just finished a jdm h22 swap into a 93 del sol, and my ecu is throwing a ect code (6). Does anyone know what the pinout on the ecu is for the ect. I'm running a chipped obd1 p28. I just wanted to make sure it is wired right before I go out and buy the sensor, this swap drained my wallet.</TD></TR></TABLE>
You talking about the ECT sensor on the head (under the dizzy) or the ECT sensor on the thermostat housing? If it is the one on the head: RED/WHT - D13 (signal) GRN/WHT - D22 (sensor ground) |
Re: Ect sensor problem (turbogixxer)
yes, it was the one on the head, and yes i had it mixed up with the vtec clip (which i hard wired since my car did not have it), and my cel is gone. Thank you very much, i've been in limp mode for 3 days and it's been killing me.
| All times are GMT -8. The time now is 05:02 AM. |
