do i need a usdm intake manifold? evap purge valve question
2 Attachment(s)
hey has anyone drilled out there jdm p73 intake manifold to get the vaccume like for the evap port? does anyone know the size or a diy?
just got my b18c jdm itr motor it’s going in my obd2 civic.. i need this to pass emissions inspection.. i know about everything else but i can’t find too much information on the evap system and purge valve i know the jdm intake doesn’t have the nipple for the purge valve but if there’s a way i can bypass it without throwing a cel that would be good it just needs to be hooked up to the computer to pass inspection no visual checks or anything.. the monitor doesn’t even have to be set just can’t throw a code too fast.. i know people don’t use this site as much as they use to but if anyone sees this and can help or point me in the right direction i would be very gratefull before i shell out money on a usdm manifold thanks |
Re: do i need a usdm intake manifold? evap purge valve question
Year make and model of your Civic? Your JDM ECUwon’t pass at all because the scanner won’t read it.
00 civic i know about the ecu i need to get a usdm itr one .. and i know about everything else like the ckf and vtec switch.. but there wasn’t a lot of info on the evap system
