Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   dizzy question?? (https://honda-tech.com/forums/hybrid-engine-swaps-18/dizzy-question-459623/)
ef ect Mar 30, 2003 08:28 PM
dizzy question??
tried to serch but it is down so here goes. putting the stock moter out of my 97 civic in to a 94 del sol. The plugs are difrent so i know i will have to splice one side of the harness but will the obd1 computer work with the obd2 distributer??
eg6ajk Mar 31, 2003 04:02 AM
Re: dizzy question?? (ef ect)
don't splice, replug the distributor. OBDI and OBDII electronics are very much the same. if you have the D15b then you can reuse your OBDI distributor for simplicty (same goes for injectors).
Newman Mar 31, 2003 10:24 AM
Re: dizzy question?? (eg6ajk)
You mean "repin" the distributor https://honda-tech.com/forums/images/smilies/emwink.gif But just like he said, OBD-1 and OBD-2 electronics are the same, thus the parts/internals.... only the plugs are different.
