The Definitive Guide to a GSR-EG Swap!
#76
#77
Re: The Definitive Guide to a GSR-EG Swap!
could be as simple as an improper ground, is it a new or used ignition switch? Check your ground to your battery, then double check you wiring and harnesses, if it still isn't wrking you may have a short in the computer or even might have the starter going out in it. Start with little **** and wrk your way up to the more costly fixes.
