d series into a classic mini
#26
Re: d series into a classic mini
the front end I have is a clubman or sometimes called clubby,
it has more room for engine swaps,
its 3-4inches longer then the other front clip, and it has more useable width space to work with, and the height at the front is a few inches taller
I plan to get a better header for the car, and this front clip will give me the space
and it helps with air flow
I ordered the budget harness and chassis adapter harness from rywire
it doesn't use a Honda main relay, it uses some reg style relays
the main relay I have right now, I got it from a mid 90's 4 door f20 Honda powered car that had been sitting in a field for a long time
I was thinking about wiring in some reg relays, I was going to do that like a week ago but didn't get time
I picked up two relays and connectors for the job
I think that's a job for this week
#27
I pulled the valve cover off to paint it
and since I had the cover off, I checked the valve to rocker arms, and they were all good
and tonight I put the cover back on and pulled the engine side of the harness
the rywire harness has shipped out, so its only a matter of time before it comes in,
so im just gonna prep the car for it
edit: the rywire harness ;left Chicago last night at 10pm, so that means i'll probably have it by Wednesday at the latest,
im trying to take my car to the dyno Saturday
that will give me 2 days to get this harness installed into my car
if not then I wont be able to take the car until the following weekend
#30
Got the harness wired into the car, the install isn't done all the way, before I tuck it up and put the dash in, I want to start the car
I turned the car over tonight but I need to hook my laptop into the ecu and make sure it's good, the fuel pump turns on, and the ecu has a green light
Tomorrow after work I will put the plug wires on and run this car up
#31
ran the car up and it has the same running issue
at 150deg temp, the engine just stalls out, no codes
so I ohm tested the tps sensor, and pin 1+2 had 615 ohms
and pin 2+3 had 6.57 K ohms
im going to replace the tps and see if that helps any
add it onto the list of sensors and parts Ive changed
so far ive done
coil, icm, ect, cap, rotors, plugs,
after this tps, I think about the only sensor I have left is the map sensor
but my tune runs off of the tps being that I have itb's
so I hope that's it
this running issue is kicking my butt
I know its not a tune problem, because the engine ran up fine before,
I never had this problem, It used to run up to normal temp and be good
so far ive done
so I hope that's it
#33
adjusted the tps 3% low speed fuel numbers, and now the car will idle at 900rpm
now I have to lower my manual set screw, and then bump the numbers back up again because the afr is running lean at idle
my idle problem was because the tune was super lean and couldn't run because it needs fuel
#34
#35
VI Boost
Audio / Security / Video
02-15-2010 12:02 PM
