Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   ctr piston? (https://honda-tech.com/forums/hybrid-engine-swaps-18/ctr-piston-398171/)
black-hatch Jan 27, 2003 12:02 PM
ctr piston?
ok i want to put ctr pistons in my b16a2 are they the same size as stock ones and when i put them in will i need to richen the fuel mixture and if i do from what rpm to what rpm also what should i retard timing to thxx?
Jeff C Jan 27, 2003 01:55 PM
Re: ctr piston? (black-hatch)
Yes, the ctr is a b16 too but with higher compression. They are both have the 81mm bore. I would think you should not need to mess with the air/fuel. :shrugs:
function83 Jan 27, 2003 02:04 PM
Re: ctr piston? (Jeff C)
you will have to shave the rod 1mm on each side to fit the ctr pistons.
http://www.imagestation.com/picture/...f/fcb8570c.jpg
pic credit: katman
Patch Jan 27, 2003 05:02 PM
Re: ctr piston? (djhatch)
Whats the CR with CTR pistons in a B16A?
speedy-crx Jan 27, 2003 06:24 PM
i have ordered some ctr pistons for my b16a first gen would i need to do this to and if so would it work without this done and if i had to do it were would i take it to get it done
owen_the_soyboy Jan 27, 2003 06:28 PM
Re: ctr piston? (needahatch)
any capable machine shop / engine shop can mill the 1mm off of the rods for not much $$$.
yes you will NEED to do this unless you have GSR/ITR/CTR rods.
speedy-crx Jan 27, 2003 06:33 PM
Re: ctr piston? (owen_the_soyboy)
hey man do you have any info on lsvtec if so aim me pissdrunxracer
X0 Jan 30, 2003 08:16 AM
Are CTR pistons/rods a good mod for a b16a2? Do you need to do any other "prep work" before running them, or can you just throw them in and go?
