Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   code 9 onzc still (https://honda-tech.com/forums/hybrid-engine-swaps-18/code-9-onzc-still-117524/)
Cereal_Killer Jan 22, 2002 07:09 PM
code 9 onzc still
well went to the junkyard today and found a 88 teg cyp sensor. as that is what my car has been throwing a code for for the past week. came homme let the car cool, swapped it out with the new (used) one, unplugged the ecu and reset under the hood. plugged everything back in and still the darn code comes up, it comes up as soon as the car is started. as suggested before i checked the wiring, turns out ok. i swapped the 2 wires for the sensor from where they were connected before, and it idles a bit better but after about a min or 2 the code comes back up (doesn't come up as soon as it's started). so not sure which way it needs to be wired as the code comes up either way. and "reparitions" said it shouldn't come up if i have it wired the right way.
so my only guess is the distributor as "rep" has said. or is ther something else i am missing?
fixhondas Jan 25, 2002 01:52 PM
Re: code 9 onzc still (91efzc)
check your cam timing- the timing belt might be off a tooth or two
