Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   Code 6 ECT Sensor... (https://honda-tech.com/forums/hybrid-engine-swaps-18/code-6-ect-sensor-290945/)
See Are X Sep 26, 2002 03:16 PM
I have an OBD-1 LS motor in my OBD-0 crx. I changed everything over so now its running OBD-0. My problem is im getting a Code 6(ECT Sensor), im using the OBD-1 LS Engine Coolant Sensor with the OBD-0 ECU, should that work right? Could it be maybe I have the wires mixed up from when I wired up the OBD-1 sensor?
