Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   B20VTEC...What octane to use? (https://honda-tech.com/forums/hybrid-engine-swaps-18/b20vtec-what-octane-use-1474661/)
christhereefer Dec 27, 2005 10:27 AM
My friend is swapping in a B20VTEC setup consisting of a JDM 98 B20B block (P3F) and a USDM 98 GSR head. The question comes up, which octane does he have to use? According to C-speed Racing.com (http://www.c-speedracing.com/h...c.php), compression ratio will be at 9.2:1, whereas a stock B20B is at 8.8:1 and requires 87 octane. Would the addition of a GSR head require 91 octane or is compression ratio still low enough to run 87? For reference, stock B16's are at 10.2:1 or something like that, and require 91 octane.
Thanks for the help.
2.0FrAnKeNsTeIn Dec 28, 2005 04:00 PM
Re: B20VTEC...What octane to use? (christhereefer)
i have always used 91 octane on my b20/vtec motors. even on 10lbs of boost. Although i have never had a gsr head. the gsr head does raise the compression ratio a bit. but i have never tried to use anything lower than 91 octane so i am not sure if it will ping on lower grade fuel. But their are some ways to find out if it is pinging/detonating.
ItsSlow Dec 28, 2005 07:12 PM
I wouldnt use anything lower than 93
2.0FrAnKeNsTeIn Dec 28, 2005 09:57 PM
you don't know what you are talking about
