B20b swap in ek hatch problems.
Hey, i just finished putting my b20b into my ek hatch, and i was having problems getting the motor to align properly. I got all the mounts mounted/bolted in and secured yet the motor is tilted downward on the crankshaft pulley area, I have innovative motor mounts on there and hopefully someone can help me figure it out. Please and thank you.
Re: B20b swap in ek hatch problems.
Should have used oem mounts
https://cimg6.ibsrv.net/gimg/honda-t...8dde7ff451.jpg
Heres a pic finally, is there any other reason why though? i mean i still have oem mounts just would rather use the stiffer ones |
Change that 2 bolt post driver side mount?
Originally Posted by tony_2018
(Post 50877766)
(Post 50877766)
(Post 50877766)
Will a civic si em1 mount fit? sorry phone wouldnt let me post
Originally Posted by HondaPartsHero
(Post 50882519)
You MUST use the "99-00 Civic Si driver's side engine bracket. When you place one side by side with the original CRV/B20 bracket, the difference will be obvious. Assuming that your Innovative mount kit is correct and isn't contributing to your problem, then replacing the bracket as I and HondaPartsHero have stated will fix the problem. The factory Honda part number is 11910-P30-000 if you cannot find a used one.
Originally Posted by JRCivic1
(Post 50885849)
| All times are GMT -8. The time now is 09:27 AM. |
