B18C1 in a EJ
As the topic states.....has anyone done this?
I am about to perform this, and was looking for some heads-up for what I will need. |
Re: B18C1 in a EJ (FyReo3)
any b series swap into an ej is the same u will need all of the same stuff only doing the c1 i will have to wire for vtec unless u have an ex model but do a search for b series swap guide and u should find all that u need....
Thanks...
Most of the info I find are based on hatches. I do not know if there is much difference between my car, which is a 99' EX. The motor is a 2000 GSR, will I have to do anything special as far as the ECU and harness? Currently I am running a chipped P28 with OBDII to OBDI harness. Will I have to change any wires? |
Re: (FyReo3)
Sup mang, hit me up on AIM, I've done a couple of these.
-PHiZ |
