B18b swap - OBD1 issue
Sup guys. We swapped a B18b from a 96 integra into buddies 2000 civic hatch. We used an EX (d16y8) harness. The motor is being run by a 2000 OBD2b B18b ecu, all I did was busted off the immobilizer chip, to enable it to run. Everything is well it runs pretty smooth, only issue is its throwing 2 codes which are:
- Secondary o2 sensor (we do not have the secondary o2 hooked up because we were planning on running an obd1 ecu originally which doesnt use a secondary o2. -CKP sensor (which is the sensor located down by the timing cover near the oil pump... once again, the obd1 b18b's do not have this sensor down near the oil pump so it is not hooked up due to the fact we originally were going to run a obd1 b18b ecu) Now. Heres the problem. The reason we arent running an obd1 b18b ecu like we originally planned is because the car wouldnt run good AT ALL with it. It would start up, idle, but it would run super grossly rich and shake super badly and pop and wouldnt rev up hardly over 3500rpms WOT. This car wants to get boosted in the very near future. Which means being tuned by Hondata, which means we've gotta figure out why everything goes to all hell once an obd1 computer is plugged in. At the time of the swap we tried for weeks and weeks before we finally gave in and just threw a obd2b ecu into it so it was driveable again. But we HAVE TO figure this out. Any ideas???? |
Re: B18b swap - OBD1 issue
and BTW. We already tried a buddies hondata s300 with a b18b map on it. And it ran EXACTLY the same as it did with a stock obd1 b18b ECU. And we tried a obd2b b16 ECU, and it ran fine.
Bump
....Someone has had to have this problem
BUMP!!!!!!!
Is it throwing any codes on the OBD1 ECU?
None at all. Just runs like absolute shit.
Originally Posted by shaylude01
(Post 45350855)
I just had an idea after re reading you post, and you mentioned you did use a conversion harness. Is it possible your using the wrong harness? Possibly a obd2a instead where you should be running a obd2b harness?
did you switch the tps and the map sensor around without knowing?
Originally Posted by Bowl_of_Rice
(Post 45351815)
Originally Posted by evilclown312
(Post 45351058)
Yeh i was referring to the jumper harness. Just throwing and idea out there.
There's a trick for the CKP sensor I believe.
Originally Posted by b18EK6
(Post 45356061)
Correct me if im wrong but from what ive read, thats what that trick is for. Not? |
You guys are absolutely positive it came out of a 96 and not a newer model....Are you positve the head is from a 96 and not newer??? Everyone knows you use the ECU for the Cylinder head you are running....could it be a 96 OBD1 block with a 98-99 OBD2A/B head? Is the obd1 b18b ecu a manual or auto ECU.
My P05 OBD1 started my 95 B18B OBD1 but wouldn't actually run the car above 2000 RPMS and kicked a code for the O2 sensor until I put a P75 A01 in it then it was fine. |
just get a OBD1 dizzy, intake mani/injectors/TB/alternator and you're good to go. run it off the OBD1 ecu. I did that on a OBD2 longblock.
How do we know that is gonna fix it though? There has to be a reason its messing up right now.
My buddy has a 2000 integra, which would be obd2b, and hes runnin obd2b to obd1 conversion harness with hondata s300 on it, which is prettymuch the same thing here that we did... Obd2a motor, obd2b engine harness, with obd2b - obd1 conversion harness running a obd1 ecu, and it ran like shit. It makes no sense at all... If buddies integra (and millions of other people) runs fine doing it, why doesnt ours???? |
Originally Posted by DC206R
(Post 45359157)
Originally Posted by HondaPartsHero
(Post 45366998)
No, the OBD2 components are exactly the same aside from plug style, that won't do anything. What brand of jumper harness are you using when you try it? If its a no name ebay type that might be your issue. There's no reason it shouldn't run just as well with the OBD1 ECU unless the jumper harness is bad or the ECU is bad.
bump
TTT!!
TTT!
Similar issue here...98 ek coupe...ex...obd2a harness hooked to a jumper harness and a p75 b18b1 ecu running a 95 b18b1....converted all my plugs...injectors, distributor, alternator, and my IAT...runs like hell...really rich and won't go past 3k...my tach jumps all over the place...I've check my distributor wiring over and over idk what is going on
do you have IAT and TPS mixed up?
| All times are GMT -8. The time now is 02:25 AM. |
