b18b in 98 hatch....
ok my teg is totaled so im forced to enter the work of civic's... http://images.zeroforum.com/smile/emcrook.gif im trying to get a 98 hatch and put my b18b in it. Now this will be my 1st swapped car so what all am i gonna need fr this swap? i've got motor/tranny/ecu am i missing anything? and how quick will this be? mid 15's?
Re: b18b in 98 hatch.... (NotQuiteJdm)
if you just get your axles. you should be ready to swap.
Re: b18b in 98 hatch.... (rainforest)
Mid 15's is probably a little harsh.
Low 15's sounds more like it, and possibly high 14's depending on where you race at. There's a few here in GA (slow area) that have run high 14's on stock LS motors in hatches. Here's a list of the shit you need from the Teg: 1. Engine 2. Tranny 3. Mounts (ask Trey which ones you'll need to actually use) 4. ECU 5. Upper and Lower Radiator hoses 6. Exhaust manifold - both portions 7. Catalytic convertor 8. Axles and intermediate shaft From here on, you can get this stuff too to make the car better. Hope you can get this shit: 1. Front Spindles with brakes. Bigger than Civic. 2. Rear traling arms with brakes and swaybar. Couldn't hurt, right? 3. Brake booster, master cylinder, prop valve. 4. Seats - were yours in good shape? IM Trey here - he's good with the "EK" tech. He will know the ins and outs of the engine and brake swaps I'm sure. I could tell you if you get a 1992-1995 hatch. Also, I *think* you can just use the Civic harness. Depending on the year of your Teg motor, you may need to use the Civic injectors and possibly re-pin or swap distributors. You had a 1995 Integra? From the Sig? If it is a 1995, you will need a jumper harness to run the OBDI ECU. Contact the user "kenji" here - he makes bad-ass jumper harnesses. Lastly - a 1992-1995 Civic would be easier and more LEGAL if you live in a state that requires the same year or newer motor in the car. Good luck! [Modified by B18C5-EH2, 12:16 AM 3/26/2002] |
Re: b18b in 98 hatch.... (B18C5-EH2)
B18c5-EG2 is right with the parts. http://images.zeroforum.com/smile/emthup.gif
for a list of the mounts and the prices check out http://www.jspectuning.com/6gen/ You'll need to use the Civic engine harness too. Good Luck, |
Re: b18b in 98 hatch.... (Trey)
Useful info https://honda-tech.com/forums/images/smilies/emthup.gif
I'm picking up a 98 LS swap for my 96 CX https://honda-tech.com/forums/images...es/emsmile.gif Trey - I've been reading that the LS harnesses are plug n play with the EK. All except one 3 wire harness. Is that not true? Thanks! |
Re: b18b in 98 hatch.... (Hybrid93Hatch)
I just got an ls motor also https://honda-tech.com/forums/images/smilies/emthup.gif
