B16B what does it take
dose any one know what it will take to swap in a jdm B16B into a 99 ex, and would it be worth it or should i get a B18c instead
Re: B16B what does it take (lsvinny)
The B16B is a destroked ITR. Meaning less displacement.
If you have the time and know how, you can swap in an ITR crank, rods and pictons and you have an ITR swap. For simplicity...... Get the B18c. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: B16B what does it take (Trey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey »</TD></TR><TR><TD CLASS="quote">
Get the B18c. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> That's debateable tho. I mean if he buys the B16B he'll have all the type-R peformance goodyness (complete R head, valve train, cams, LSD transmission, etc) only downside (for some) is that it's 1600cc. Where-as if he went GSR, he'd have to start from point zero and work his way up w/performance engine parts. The only real perk of a B18C/GSR/SiR engine is the 1800cc displacement. Like you said, he could stroke UP the B16B https://honda-tech.com/forums/images...es/emsmile.gif Something to think about before he buys. I'd personally go with the B16B seeing how it has way more performance goodys over a bland dual butterfley B18Crap. A B18C-R on the other hand, puts this talk to rest. |
Re: B16B what does it take (Katman)
is it a direct plug and play or is there some work that has to go into it, I'm not scared to get dirty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvinny »</TD></TR><TR><TD CLASS="quote">is it a direct plug and play or is there some work that has to go into it, I'm not scared to get dirty.</TD></TR></TABLE>
its a direct swap and should come with everything needed to complete the swap. |
Thanks, i think I'm going to go with the B18c, I like toque.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvinny »</TD></TR><TR><TD CLASS="quote">Thanks, i think I'm going to go with the B18c, I like toque.</TD></TR></TABLE>
I hope you do mean the JDM ITR B18C, because I'd get a Civic Type R motor with GSR/Type R crank whaodie. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvinny »</TD></TR><TR><TD CLASS="quote">Thanks, I like toque.</TD></TR></TABLE>
You like toque eh? toque a smoke? |
opps, i mean torque, but i`d toque a smoke too.
and i do mean the itr |
| All times are GMT -8. The time now is 11:22 AM. |
