b16a2 in 94 vx
I have a 94 honda hb vx. I am swapping in a full swap b16a2 and i wuz wonderin wut additional wires i needed. I herd i can use my stock harnesses and then just wire up the knock,o2,and vtec. since i have a vx with the vtec-e motor, is vtec already wired, and if it is can i just use that wire with my b16a2 swap?
Bump for you cuz I want your valve cover if it says vtec-e on it!
Re: (SVOboy)
bump for info.
sure, its for sale |
Re: (94hatchvx)
You will also need to rewire your O2 sensor since the VX setup is a 5 wire O2 and the B16A uses a 4 wire O2. If you search here you can find wiring info to make this mod.
John |
Re: (1fastVX)
so i can use the stock harness? and can i use the vtec wire that is there if there is one. and the only other things i gotta do is wire knock and o2?
