B16a w/ S2 Stage 1, what ecu for 8500rpm?
I'll be using ITR valvetrain parts and CTR pistons. Should I go the Hondata route (OBD I changeover and stage II) or should I chip the PWO I have and use a V-AFC for fuel tuning?
Re: B16a w/ S2 Stage 1, what ecu for 8500rpm? (NiMhist)
hondata would be about the same amount as chipping and buying the v-afc. but you would have better control of fuel /timing....the hondata might even be cheaper.
Re: B16a w/ S2 Stage 1, what ecu for 8500rpm? (skunkwhat)
Thanks, anyone else have suggestions ?
[Modified by NiMhist, 2:07 PM 1/12/2003] |
the older PW0/PR3 doesn;t really benefit all that much from the hondata unit. just chip it and save your money. there is no real need for the VAFC either.
Re: B16a w/ S2 Stage 1, what ecu for 8500rpm? (eg6ajk)
Thanks
