B16A head on GSR block? Different timing belt?
Started putting the motor back together and the timing belt just wasn't working. I'm putting a stock B16A2 head on a 99 GSR block. GSR water pump, GSR oil pump, B16 crank pulley. Which timing belt do i need?
Thanks. |
Re: B16A head on GSR block? Different timing belt? (blownsi)
You will need a gsr timing belt and head studs for that poormans ITR setup. http://images.zeroforum.com/smile/emsmile.gif
