B16 swapped out for B18c1
I'm not sure which B16 engine was taken out of the car, but it is a B18C1 how would I be able to tell if this swap was done correctly, other than I did drive it home almost 200 miles? Is there anything to lookout for, electrical or mechanical wise? Any specific parts I should look for? Is equipped with a Jackson supercharger. Car is un-tuned.
Re: B16 swapped out for B18c1
Did you ask the previous owner what was done to the car? Since it does have a supercharger, you could assume the injectors and fuel pump have been changed. At this stage you are probably better off taking it to a shop to have them look over the car for you and have it tuned also. Whatever you do don't drive the car hard until you get it tuned.
Jesterian
09-25-2005 08:48 AM
