Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   b16 swap code 3 (https://honda-tech.com/forums/hybrid-engine-swaps-18/b16-swap-code-3-a-629002/)
DAMCOOLDAV Sep 24, 2003 01:05 PM
b16 swap code 3
Hey guys i got a b16 swap done at the end of august.......and i had gotten a CEL, it was a code 3, so i replaced and inspected all the vacuum lines, redid all of them so there all good. I also just got a map sensor from a 90LS in a junkyard and put that on yesterday and it still is giving me a code 3, so i don't get what the problem is?? The only other thing i can think of that it could be is the ecu itself, or the wiring........can anybody help me??
DAMCOOLDAV Sep 26, 2003 02:47 PM
Re: b16 swap code 3 (DAMCOOLDAV)
does anybody have any ideas i could try?
ZaxEG Oct 2, 2003 06:48 PM
Did you try pluging the MAP itself stright in into the nipple and making sure that it is connected to the ecu? i know it sounds dumb but thats the only hook ups it needs
VTECVillain Oct 2, 2003 07:52 PM
Have you reset the ECU since you've made the changes? The ECU can store the codes even after you fix the problem and will need reset to clear them.
DAMCOOLDAV Oct 3, 2003 11:25 AM
Re: b16 swap code 3 (VTECVillain)
Well I had the battery cable off while i changed the map sensor, and then just connected it when i was done, so doesn't that count as resetting it? and ZAXeg i don't know what u mean, plug it into what nipple?
poison Oct 3, 2003 04:38 PM
Assuming you have an OBD0 swapped B16, you need to configure your MAP sensor and vacuum lines as described:
http://www.phatwhippincrx.20m.com/images/vacuum.jpg
https://honda-tech.com/forums/images/smilies/emthup.gif
DAMCOOLDAV Oct 5, 2003 07:53 PM
Re: b16 swap code 3 (poison)
yup i'd seen that before and had done it just so.......still don't know what the problem is.......guessing its my ecu, gonna call HMO tomorrow if i can get a phone card.
