b16 sirII into a 95 civic ex
New User
im in teh middle of a swap b16a sirII into a 95 civic ex. i havent gotten to the wiring yet. does anyone
know if and what ther differences in the harness is gonan be? what do i have to do to mine? i have an
odb II computer that came with teh engine, so what do i have to do to the harness????
1 Post
Re: b16 sirII into a 95 civic ex (rainforest)
No no no...go to 5th gen..very different. You'll have a headache for weeks if you try 6th gen wiring.
By the way, you can't use that computer that came with your motor. The best thing to do is chip your stock EX computer to DOHC specs then run it with that motor. Also, use your stock wiring harness, basically plug and play since you already have VTEC. Check out Hybrid for more wiring info though.
[Modified by fowler, 6:27 AM 9/25/2001]
Re: b16 sirII into a 95 civic ex (fowler)
http://www.hybrid.honda-perf.org/tech/5gtech.html
Use your EX engine harness and the SiRII ecu. You will be fine with that. Or get yoru ecu reprogrammed with a Mugen program. Check http://www.jdmhondaparts.com
