Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   B16 Compression (https://honda-tech.com/forums/hybrid-engine-swaps-18/b16-compression-397159/)
rca90gsx Jan 26, 2003 11:08 AM
B16 Compression
posted in Tech forum as well.... Wondering what a stock B16a (jdm first series) should put out when doing a compression test?
Thanks for your time,
Richie
PhatOptimo Jan 26, 2003 12:01 PM
Re: B16 Compression (rca90gsx)
1g B16a Compression #'s
Standard (new) is 185 psi
Low limit is 135 psi
Difference between cyls should not be above 28 psi
*NOTE* Use a fully charged battery when doing a compression test.
rca90gsx Jan 26, 2003 12:46 PM
Re: B16 Compression (Phat_Optimo)
Thanks very much for that. I'm used to the 4G63 engines... still learning on the hondas. This is a great forum for that.
Richie
ALLmotorCRX Jan 26, 2003 05:06 PM
Damn my b16 is hitting the 205 marks on every cylinder. Now i know why i use Mobil1 supersynthetic. https://honda-tech.com/forums/images/smilies/emwink.gif
PhatOptimo Jan 26, 2003 05:47 PM
Re: B16 Compression (ALLmotorCRX)
Carbon build-up will cause high compression numbers.
irev210 Jan 26, 2003 10:22 PM
185 is cold test right?
PhatOptimo Jan 27, 2003 07:51 AM
Re: B16 Compression (irev210)
No the engine should be warm (radiator fan come on) when doing a compression test. Also remove the 2-p connector (ignition coil primary lead) form distributor.
