axle nut and clutch cylinders question
how many of you replaced your axle nuts when you swapped motors? helms manual suggests it but i want know how many actually do it. also, is there a different axle nut for D and B series axles? would you be able to reuse your stock engines axle nuts on a b18 swaps axles?
one more, will an integra clutch slave cylinder work with a civic clutch master cylinder? in other words, can i use the clutch slave cylinder that comes attached to a b series tranny with my civic clutch master cylinder. TIA |
Re: axle nut and clutch cylinders question (deviant1)
The axle nuts are the same.
I've reused mine 5 or 6 times now. lol You can use the Bseries slave cly, but I dont think there is any advantage to having it. I'm pretty sure they are exactly the same. https://honda-tech.com/forums/images/smilies/emthup.gif |
I replace my axle nut every time. No real reason. There cheap so i do it.
