Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   Automatic Swap (https://honda-tech.com/forums/hybrid-engine-swaps-18/automatic-swap-662854/)
tanomack Oct 29, 2003 11:31 AM
Automatic Swap
https://honda-tech.com/forums/images/smilies/mad.gif https://honda-tech.com/forums/images/smilies/mad.gif https://honda-tech.com/forums/images/smilies/mad.gif https://honda-tech.com/forums/images/smilies/mad.gif https://honda-tech.com/forums/images/smilies/mad.gif https://honda-tech.com/forums/images/smilies/mad.gif https://honda-tech.com/forums/images/smilies/mad.gif https://honda-tech.com/forums/images/smilies/mad.gif
Car: 92 DX Hatch Auto
Motor: 94 LX B18B Auto
Has n-e-1 done this yet? Do I need special mounting or can I use the same mounts? I've noticed that the top tranny mount doesn't look like it 's gonna line up.
The spacing is really tight in there. Like less then a cm between the crack pulley and the frame and same for the tranny to the frame. Is this right?
n-e help would be much appreciated...
VTECVillain Oct 30, 2003 04:22 AM
Re: Automatic Swap (tanomack)
I'm sure it's been done but it's hard to find good solid info on auto swaps sometimes since they aren't very common. When doing a manual B series swap in a manual EG Civic, you can use the B series upper tranny mount or the stock upper tranny mount. I would imagine the same rule would apply to an auto B series tranny in an auto EG chassis: you should be able to use the stock auto or Integra auto upper tranny mount and it should line up and bolt in.
tanomack Oct 30, 2003 10:00 AM
I know Place racing makes a special mount that aligns the tranny when doing a auto to manual but they don't know about auto to auto. The problem I noticed yesterday when I aligned all the mounts is that the tranny's too big. I'll try and pound the frame in like the H22 swaps and see if it fits... wish me luck!!
