Ask your H22 Questions Here
#52
Re: (vtecspeed1320)
for an obd1 jdm h22 what is the usdm counterpart? Id like to order the follwoing but dont know for which model/year, timing belt,waterpump, sparkplugs/wires, aem fuel rail, cam gears. ??
#53
Re: (SohcPower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SohcPower »</TD></TR><TR><TD CLASS="quote">for an obd1 jdm h22 what is the usdm counterpart? Id like to order the follwoing but dont know for which model/year, timing belt,waterpump, sparkplugs/wires, aem fuel rail, cam gears. ?? </TD></TR></TABLE>
Just order your parts for any usdm H22. The water pump, timing belt, and cam gears should be easy to locate. As for the plug wires it just depends on your distributor. If you have an external coil then order your wires for a 92-96 Vtec prelude. The rail could be different. What kind of car are you putting this in?
#54
How much of a difference is there in quickness b/w a stock h22 and stock b16? Also, when buying axles, is it smarter to go with hasport axles or mix and match stock axles?
#55
Re: (PhoebeusFenix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoebeusFenix »</TD></TR><TR><TD CLASS="quote">How much of a difference is there in quickness b/w a stock h22 and stock b16? Also, when buying axles, is it smarter to go with hasport axles or mix and match stock axles?</TD></TR></TABLE>
a big difference, and for axles, I think that depends on how much power you ultimately want from the motor, and how much of a drop your suspension has.
#56
Re: (BigBlockH22atch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch »</TD></TR><TR><TD CLASS="quote">Just order your parts for any usdm H22. The water pump, timing belt, and cam gears should be easy to locate. As for the plug wires it just depends on your distributor. If you have an external coil then order your wires for a 92-96 Vtec prelude.</TD></TR></TABLE>
Some parts are different.
#57
Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">
Some parts are different.</TD></TR></TABLE>
Thats kinda what I said..... LOL
#58
Thats kinda what I said..... LOL</TD></TR></TABLE>
shouldn't you be under a dash somewhere ? Did you ever get the brakes to stop blowing fuses?
#59
Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">
shouldn't you be under a dash somewhere ? Did you ever get the brakes to stop blowing fuses?</TD></TR></TABLE>
Yea I should be under a dash but damn it feels good to stand up straight. I think I have the problem isolated but only time and a lot of cursing will tell. Should have it fixed today.
<*knocks on wood*
<*knocks on wood*
#60
Re: Ask your H22 Questions Here (BigBlockH22atch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch »</TD></TR><TR><TD CLASS="quote">GD I HATE WIRING HARNESSES!!!!!</TD></TR></TABLE>
They are not that bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch »</TD></TR><TR><TD CLASS="quote"><*knocks on wood*</TD></TR></TABLE>
Knock the kid out that did the wiring before!
#61
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch »</TD></TR><TR><TD CLASS="quote">Thats kinda what I said..... LOL</TD></TR></TABLE>
I meant the thermostat
#62
good luck. after I installed my remote start alarm, my back hurt for the next 3 days. And that was less work that trying to track down those damn wire gremlins. I feel your pain.
#63
Ditto
1. If you still need an underdash harness, I've got one from a 92-95 hatch Ill sell you for $15+shipping.
2. I've been in a training class since Tuesday, so I haven't really been on much. Plus, I'm still pissed about the other thread. They could have atleast moved it to the kills forum or GDD. That's all BS anyways, oh well.
3. Work is boring.
4. The thermostat on 92-96 JDM H22A's uses the 97-01 USDM H22A Thermostat. I spent a lot of time figuring that one out, haha.
3. Work is boring.
#65
Re: (SohcPower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SohcPower »</TD></TR><TR><TD CLASS="quote">for an obd1 jdm h22 what is the usdm counterpart? Id like to order the follwoing but dont know for which model/year... ... aem fuel rail</TD></TR></TABLE>
any specific reason you want an aem fuel rail? the stock rail is more than capable of supporting 150% the stock HP.
#66
Re: (IHateJDM)
HAHAHA. I fixed the problem. The car is running, the brake lights work, and so do the power windows. I had to replace every single harness in the car due to burnt ground wires. I could have gotten to the ******* who made this mess I would have beat the daylights out of him. Hell if I ever run across him I'm probably still gonna brake his nose for all my trouble. The good thing is I got a 98 ls motor for changing all the wiring.
Might be able to make a little money off of it.
BTW thanks again for everybody's help.
#67
BTW thanks again for everybody's help. </TD></TR></TABLE>
ahh.. dont mention it, im glad i could be of service to you buddy. *pushes kenny out of way*
#68
Re: (hondaZvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">
ahh.. dont mention it, im glad i could be of service to you buddy. *pushes kenny out of way*</TD></TR></TABLE>
HAHAHAHA.....you guys are nuts.
Where the hell is Roti?
#69
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch »</TD></TR><TR><TD CLASS="quote">Might be able to make a little money off of it.
enough for the swedish back massage you need after crawling around on your back for so long?
#70
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch »</TD></TR><TR><TD CLASS="quote">HAHAHAHA.....you guys are nuts.
Where the hell is Roti?</TD></TR></TABLE>
i was just thinking the same.. havent seen that hamster stealing rug pilot for 2 days now...
#71
Re: (hondaZvic)
enough for the swedish back massage you need after crawling around on your back for so long?</TD></TR></TABLE>
Thats what the old lady is for. LOL just dont tell her I said that.
i was just thinking the same.. havent seen that hamster stealing rug pilot for 2 days now...</TD></TR></TABLE>
The last I herd he was in some anti-terrorist training class. I think he is going to be a flight attendant. He really likes it when you smack him on the *** while he is getting your sac of nuts....LOL
#72
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch »</TD></TR><TR><TD CLASS="quote">HAHAHA. I fixed the problem. The car is running, the brake lights work, and so do the power windows. I had to replace every single harness in the car due to burnt ground wires. I could have gotten to the ******* who made this mess I would have beat the daylights out of him. Hell if I ever run across him I'm probably still gonna brake his nose for all my trouble. The good thing is I got a 98 ls motor for changing all the wiring.
Good to hear you figured it out
#74
Just order your parts for any usdm H22. The water pump, timing belt, and cam gears should be easy to locate. As for the plug wires it just depends on your distributor. If you have an external coil then order your wires for a 92-96 Vtec prelude. The rail could be different. What kind of car are you putting this in?</TD></TR></TABLE>
into a 00 ex, the motor is a jdm obd1 h22a.
#75
Re: (SohcPower)
into a 00 ex, the motor is a jdm obd1 h22a. </TD></TR></TABLE>
92-96 JDM H22A's uses the 97-01 USDM H22A Thermostat. My coupe is a 99 ex with a USDM H22a and I hate it!
