---Adjusting camsprockets & GSR intank fuel pump---
New User
When you advance or retard your camsprockets which way do you turn the sprocket.....Do you turn the sprocket towards the firewall to advance or do you turn the sprocket to the front of the car to advance...
Also is there any difference between a gsr intank fuel pump and a delsol s intank fuel pump...Wat is the gsr fuel pump rated at and wat is the delsol s fuel pump rated at...
Thanks for the info...
