98 Honda Wont Revv Past 4k
I have a 1998 Honda civic with a B16A swap(100k plus on motor, 70k on car) and it won't revv past 4k rpms. It's got a skunk2 intake manifold, AEM intake, type r rep headers, blox racing cams. Phearable ECU P28 with ODB0 to OBD1 jumper harness. Recently replaced IACV, TPS, Map, and an o2 sensor. Only running 1 o2 sensor(precat). I think I've ruled out limp mode. It doesn't cut fuel and/or die down. Timing is set good at 16 degrees advance. Engine is feels very healthy and all cylinders have 130-140 compression. It feels like the revv limiter is set to 4k. If the phearable ECU has a 2 step setting, how do you turn it off? If it's not 2 step and it is in limp mode, what do you guys think will get me out of limp mode? There was one time about a month ago I was driving it and it all of a sudden let me revv past 4k. But shut my car off to put gas in, turned it on and wouldn't let me revv past 4k again. Thoughts?
Re: 98 Honda Wont Revv Past 4k
Does your CEL work?
Originally Posted by mini_geoff
(Post 51533033)
If your speed sensor is not sending the correct speed to the ECU, it will not dissengage 2 step. Is the distributor OEM or one from Autozone/O'reilly's? I have not had good luck (nor my local tuner/builder) with the remans. |
