92 eg f20b swap with a h22 lsd issues
Took out the old trans I had h22 and put another one with a lsd for some reason the axle position change its at a very hard angle what could this be from any further info or recommendations are welcomed
Re: 92 eg f20b swap with a h22 lsd issues
The H22 from prelude type SH use a different transmission and half shaft. Research and check if that is your issue.
Any 92-95 h22 and f series accord should fit the same transmissions |
