Delete found answer else where
Found my answer elsewhere no longer need this posting
Re: 70MM Sk2 TB & Manifold question(not installation related)
So you're asking which block is better for the intake? Shouldn't you be more concerned with which block is better for boost, if that's what your intent is?
Go B18B, the cylinder walls are better suited for higher horsepower. |
