2000 B18c1 GSR swap into 92 civic Si Throttle cable
Old 06-22-2017, 05:40 PM
SiSiah's Avatar
Icon5 2000 B18c1 GSR swap into 92 civic Si Throttle cable
Hello, my name is Josiah. I am currently working on a b18c1 for my 92 civic Si, I plan to use a skunk2 IM and throttle body in place of the snail shell, however, from what I've read, I got the idea that I may need a different throttle cable then the one already in my 92 civic Si and possible specific brackets to guide the cable to the throttle body. If anyone has expirence with my particular situation or similar I would greatly appricate the info thank you.
Old 06-22-2017, 11:39 PM
JRCivic1's Avatar
Default Re: 2000 B18c1 GSR swap into 92 civic Si Throttle cable
If you intend to use the GSR throttle body, you will need a GSR throttle cable and firewall bracket for proper installation. If you end up using a different throttle body (non-GSR style) which requires a cable that pulls from below the throttle wheel and lays horizontally across the intake manifold runners, you will need to purchase the ITR throttle cable and stay bracket.
Old 06-23-2017, 05:00 AM
SiSiah's Avatar
Thank you very much. I looked up the ITR throttle cable and bracket and was also to see some pictures of the bracket you mentioned mounted on the skunk2 intake, which is the one I plan to use.
Old 06-23-2017, 05:53 AM
ontariorider's Avatar
I went threw the same thing and just ordered an itr throttle cable from the dealership.
Old 06-23-2017, 06:41 AM
SiSiah's Avatar
Okay, yeah I'm gonna do the same, I have bought a couple of parts from my local lithia Honda, which I prefere to eBay. Lol
Old 06-23-2017, 08:35 PM
JRCivic1's Avatar
So you are going to change the throttle body too, right ?!?
Old 06-23-2017, 09:01 PM
SiSiah's Avatar
Correct that is the plan
Old 06-24-2017, 02:32 PM
Chance EG's Avatar
"I plan to use a skunk2 IM and throttle body in place of the snail shell"
C'mon buddy...
Ej8_KiD
10-29-2009 09:24 PM
krucial7integra
01-11-2007 12:31 PM
whiteblurr
01-19-2004 07:06 PM
drumking15
04-10-2003 06:46 AM
Quick Reply: 2000 B18c1 GSR swap into 92 civic Si Throttle cable
