[FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
#101
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">What axles you using? and how are the place mounts treating you? and you brought the F20b as a long block?</TD></TR></TABLE>
**EDIT** the right axle is giving me problems (passenger side)
axles...
right side is 90-93 integra axle
left side is 89 integra axle, 94 prelude inner cv joint and the outer is 94 integra.
Prelude intermeidate shaft.
The mounts are ok. The tranny mount seems ****.
It sits kinda funny, its only a single shear bracket
Yea bought the f20 longblock,
h23 tranny
Modified by tHIS oNE at 9:45 PM 12/2/2003
axles...
h23 tranny
#103
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (Root79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 »</TD></TR><TR><TD CLASS="quote">It is 2.0 block with 2.2 V-tec head?</TD></TR></TABLE>
haha nope..
ITs all 2.0 man..
The head is a p13 head though, identical to the h22 ****
haha nope..
ITs all 2.0 man..
#104
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (tHIS oNE)
Well im having some axle trouble.
The first passenger side axle i got was 90-93 integra. Fit fine, well when i put the motor in the car, i raised it up a good 3 inches from where i had it(which was on the locks). Once i got the car running i wanted to lower it some because it had plenty of ground clearance on the oil pan. About that time the axles started popping and I thought it was a junk axle. It kept popping out of the tranny
Well i took it back, exchanged it and raised my car up. everything is fine.
Well today i decided i wanted to try to lower it back down agian, so i did and the popping came back.
Raised the car back up and its fine.
So obviously the problem is the axle is binding.
Well the ride height is ridiculously high, a good 2 inches of fender gap. I want to lower it an inch or so.
Is there a longer axle i can try, any ides?
anyone else's car have this problem......?
#105
you try a 86-89 teg axle yet? you using the teg inner CV or lude?
#106
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">you try a 86-89 teg axle yet? you using the teg inner CV or lude?</TD></TR></TABLE>
no i havent tried anything but the integra axle..
I guess i could try it with a prelude inner...
I thought the 89 teg was shorter?
#107
What woul be a better shell for a H22 swap? A 94+ teg or a 92 civic hatch!
#108
this one,
What kind of mounts are you using? I've never seen the yellow one before.
#109
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (4gotpasswordAGAIN)
Which is a better shifter assembly? as far as lightness, fitment, shifter feel?
The prelude or accord shifter? This is what hasport used in there project integra, I think its an early 90's accord shifter but correct me if im wrong:
#110
The yellow mounts are Place Racing mounts. With the HCP mounts, it's recommended to use either the 92+ Prelude shifter & linkage or the 94+ Accord shifter & linkage. The 90-93 Accord shifter & linkage doesn't want to work well in the Civics/Integras.
#111
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gotpasswordAGAIN »</TD></TR><TR><TD CLASS="quote">this one,
Yea place racing...
They are nasty. I need to paint them or something
They seem ok other than the tranny mount, its junk
Yea place racing...
#112
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote"> With the HCP mounts, it's recommended to use either the 92+ Prelude shifter & linkage or the 94+ Accord shifter & linkage. The 90-93 Accord shifter & linkage doesn't want to work well in the Civics/Integras.</TD></TR></TABLE>
Is this something you learned through experience or through the grape vine? What are secific issues with using the 90-93 accord linkage? What does Hasport recommend using?
#113
Q:
Which mount kit will give me the most clearance between the inmanifold and the firewall?
Q:
Which mount kit keeps the axles the straightest?
Modified by 4gotpasswordAGAIN at 10:25 PM 2/10/2004
Q:
#114
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gotpasswordAGAIN »</TD></TR><TR><TD CLASS="quote">Q:
Which mount kit will give me the most clearance between the inmanifold and the firewall??</TD></TR></TABLE>
from what Ive seen the Hasport has best clearence from the firewall.
Which mount kit has keeps the axles the straightest?</TD></TR></TABLE>
The HCP takes this one.
of course this is only my opinion.
#116
A little off topic but what brake setup are y'all using? did you just slap a big brake kit on or did you use a hybrid setup like from a teg? Ecuse my noobishness but i have searched and have not found a post on this.
#117
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (Timmay)
FYI guys. I am using the 91 Accord linkage and shifter without any problems. Of course with the bulkier accord shifter the panel does not sit flush but that is nothing a lil trimming cant fix...
As for brake setup an all around GSR setup would work great. I am using that along with a fastbrakes upgrade kit though for the front and back along with stainless lines, 15/16 master cylinder from an RS integra and 40/40 prop valve and the car stops very balanced..
#118
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (Jason kiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason kiDD »</TD></TR><TR><TD CLASS="quote">FYI guys. I am using the 91 Accord linkage and shifter without any problems. Of course with the bulkier accord shifter the panel does not sit flush but that is nothing a lil trimming cant fix...</TD></TR></TABLE>
What kind of car do you have? EK or EG/DC?
#120
If anyone of you guys have a 94+ integra axle laying around, im trying to pick out which cv joint it is out of this pile of axles.
I need to know some measurements
This is the drivers side outer cv joint, dont think it matters which side though
Need to know the diameter of the body
The length of the joint
the length of the spindle area
and the lenght of the grooved portion on the spindle area
Thanks
Thanks
#121
Re: (tHIS oNE)
I am also having axle problems with a lowered car- 96 H22 hatch. i am using the 89 teg axles with accord int. shaft, but want to try the Prelude inner joints to see if that'll free up some room- My question is which prelude can i use as a donor? I'm htinking 92-96, but does it matter as far as h22 or h23? it seems like those axles are the same. whatcha guys using? Thanks!
PS, it's been a while since i've posted- Glad to be back!
#122
Re: (EK22Tim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK22Tim »</TD></TR><TR><TD CLASS="quote">I am also having axle problems with a lowered car- 96 H22 hatch. i am using the 89 teg axles with accord int. shaft, but want to try the Prelude inner joints to see if that'll free up some room- My question is which prelude can i use as a donor? I'm htinking 92-96, but does it matter as far as h22 or h23? it seems like those axles are the same. whatcha guys using? Thanks!
PS, it's been a while since i've posted- Glad to be back! </TD></TR></TABLE>
ill trade you
i need the accord shaft...
i have a 94 prelude inter shaft and inner joint for you...
PM me if you are interested...
Matt
ill trade you
Matt
#123
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tHIS oNE »</TD></TR><TR><TD CLASS="quote">
Hehe, look at the nice Rota polish under all that black paint..
where's your radiator fan?!!
#124
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (Hatch-E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch-E »</TD></TR><TR><TD CLASS="quote">
where's your radiator fan?!!</TD></TR></TABLE>
didn't have one at the time, those pics were right after doing the swap.
Actually still dont have one.
It runs fine, its really cold down here right now so...
it will start getting hot after about 20 mins of idling...
#125
Re: (EK22Tim)
PS, it's been a while since i've posted- Glad to be back! </TD></TR></TABLE>hey Tim I swaped out the 89 teg joint with that of Prelude joint and cup and it works fine., good to have you back I was wondering where you were.
