92 jdm d15b (auto) into 91 usdm crx (manual) swap
Old 03-18-2017, 04:53 AM
twincammy's Avatar
Post 92 jdm d15b (auto) into 91 usdm crx (manual) swap
Hi guys, looking for some advice on this swap. i have the chance of a complete jdm d15b Auto Delsol and fancy it do the swap into my crx DX.
obviously ive tried searching and theres a lot of info out there, but also a lot of dead links etc. besides i cant find any info on this exact swap....
basically the main items i need confirmed are
1.will the crx 5speed tranny bolt straight up? (research ive done seems to indicate yes)
2. will the auto ecu will be no use for the manual car? (research says a chipped p28 would run the d15b ok?)
3. i would have the two complete running cars, besides an ecu what else would i need?
apologies in advance for typical newbie type post, but i have tried searching..
Old 03-19-2017, 06:05 PM
EG RussE's Avatar
Default Re: 92 jdm d15b (auto) into 91 usdm crx (manual) swap
https://honda-tech.com/forums/honda-...to-ef-2891815/
some good info about transmission
You will benefit alot more with a si transmission. Better acceleration.
id recommend converting to obd1
Po8 ecu would be great or a chipped ecu or hondata and tune
try searching d16z6 into a crx its a identical swap
shairacer
06-10-2010 05:45 PM
91crix
08-25-2009 06:47 PM
mnneon
07-10-2005 06:34 PM
thrty8street
15
02-08-2004 09:43 AM
Quick Reply: 92 jdm d15b (auto) into 91 usdm crx (manual) swap
