**Official H2B Discussion thread **
Steve at Heart
Re: **Official H2B Discussion thread **
Newbee, a quick parts list should be as follows
Balance Shaft delete from Kaizenspeed
H2B kit
H2B header
Engine/trans mounts (B series I believe?)
Assuming you'd be going OBD1 like most....
OBD1 ECU (p28 or p72) with a tuning solution (Chrome, or Hondata….I'd vouche for Hondata)
OBD1 Alternator (I'm using a B series alternator as QSD recommends with their kit)
OBD1 Distributor (td60u)
High impedance injectors
Anything you want to do on the transmission side is all B series from the flywheel on out.
I think that should be a good start. If you're H23a, you already have the single row pulley. You may also need to get the QSD alternator relocation bracket but depending on which H2B kit you choose, you may not need it.
And COOP I've been really broke the last year as the result of switching careers, but overtime is coming soon so I'll be able to save a few pennies. Looking at head packages next.
H2B kit
H2B header
What all headers are making good power all motor these days. My old myers broke and in the market for some new ones, just not trying to spend 1000 plus right now.
Steve at Heart
Highend Autosport sells the Logic budget H2B header, plenty have made power with it.
Whitfield also makes a H2B header.
@RGHTBrainDesign what power are you making? Just subscribed to your thread.
@h2bh23 did you check with Myers about repairing the header?
Yes. He told me it's not repairable. It is really old. Some how when I left the track, every runner was cracked pretty much all the way around. Now the flange is still on the head and the header is in the car. I'm looking for a header that will allow 300whp. Planning on changing a few thing so trying to buy the best bang for the buck.
I'm looking at the 1320 hood exit v.2 or the whitfeild header. If anyone has any input on them two to lead me in the right direction, I'm all open. I've been looking but the stuff I'm reading is so old I dont kniw if they've changed designs or anything.
Whats up yall, its probably been asked but theres like 830 some responses on this thread and i couldnt find it. So i baught a h22a4 type sh.. i know rookie mistake... for a h2b swap in my eg. My question isnwill this engine really not work for the swap or is there a way or adapter for it? This is my first h2b swap so trying to figure everything out. Any help would be apreciated
ok yea that was my question. Was just mating the b trans to the block. Thanks for the input didnt know that kit would work
Location: 9/11/01 WTC Never Forget, United States Of America
Hello everyone,
Sorry for the question but to replace oil pump on H2B EK would I need to pull the motor?
Has anyone had success fitting an ATI Harmonic Balancer (#918468) to their H2B swap in an EG/DC2 without running into frame clearance?
Does anyone have dimensions of this part vs. the OEM in mounting depth added to crank?
Cheers,
-Ryan
Cheers,
-Ryan
Steve at Heart
I'm not sure how EG/DC clearance is for frame rails but I had to shave a .25" off the inside of my Euro R pulley to give some room in a EF.
Are you able to cut and box the frame for more room?
I appreciate the insight, Bently_Coop!
