Honda S2000 Honda S2000
Clutch noises
Old 11-19-2006, 01:07 PM
Moemers's Avatar
Default Clutch noises
So everytime i put it in first gear and start going forward i let off the clutch and it makes the worst noise, like a buzzing and then grinding.
Wtf do i do?
Old 11-19-2006, 10:20 PM
s2kdre's Avatar
Default Re: Clutch noises (Moemers)
common problem on the early models, aftermarket clutch will fix that.
Old 11-19-2006, 11:25 PM
- BSeRiouS -'s Avatar
Default Re: Clutch noises (jdmhonda)
^^^^It might be the infamous "Buzzing Clutch" in AP1's.
You feel it a lot more when you down shift break. I got a Stage II after my clutch went out in the canyons, and the buzzing went away. I love it. hahaha
Old 11-20-2006, 01:04 AM
iam7head's Avatar
Default Re: Clutch noises (OBSeRiouSo)
you'll get used to it after a while, it's my second OEM/EXEDY clutch and it's buzzing too...just matter of time
Old 11-20-2006, 10:54 AM
Francesco's Avatar
Default Re: Clutch noises (iam7head)
Clutch buzz is a common issue, no worries.
Old 11-20-2006, 12:39 PM
* B A N N E D *
Mr. Projekt's Avatar
The buzzing is normal, the grinding might indicate a worn clutch or TO bearing.
Old 11-20-2006, 09:07 PM
jdm-ray's Avatar
Location: home of Marciano/Haggler, city of champions, MA
i only hear the buzz when i down shift not when i engage in 1st gear. feels like a slight rumble or like its comming from the exhaust. i actually like that soud
Old 11-21-2006, 07:28 PM
Moemers's Avatar
Default Re: (h22boy)
how much is it gonna cost me to get a new clutch at the dealer?
Old 11-21-2006, 09:46 PM
* B A N N E D *
Default Re: (Moemers)
Around $360-$380 for a new pressure plate, TO bearing, and friction disk.
Old 11-22-2006, 05:31 AM
M.A.R.C.'s Avatar
Default Re: (FR-MOB: Projekt)
just went with an ACT HDSS in my S. Buzzing/rattling gone and the **** grabs like a bear. Feels just like the XTR6 I had in the Civic.
Old 11-25-2006, 02:33 AM
HYPEBEAST!'s Avatar
its not the LSD?
Old 11-26-2006, 01:02 AM
Moemers's Avatar
Default Re: (HYPEBEAST!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYPEBEAST! &raquo;</TD></TR><TR><TD CLASS="quote">its not the LSD?</TD></TR></TABLE>
sounds like it's coming from the front.
what could be screwed with the LSD?
Old 11-27-2006, 06:58 AM
oheim's Avatar
If your S2k is MY00 or MY01 then there is a TSB out on this. I used to drive a MY01 and when I noticed this problem (most 00-01 s2k's have this problem), I took it into the dealer and they fixed it under warranty. You probably don't have a warranty anymore, but I just wanted to let you know that you do NOT have to get an aftermarket clutch. Honda has a redesigned clutch. They put my new clutch in when I had 4k miles. Never had anymore problems through 23k, when I sold the car. BTW advice for the future: don't ever sell your s2k!!!! I sold my 01 and it was a HUGE mistake!!! I am now the proud owner of a MY07 and couldn't be happier! I could however have a lot less debt if I would have kept the first one!
Flexer
04-16-2004 07:43 AM
echo999
12-17-2002 01:57 PM
STOLEN - ITR 98-0652
11-26-2001 12:18 PM
Quick Reply: Clutch noises
