oil change then check engine light on
#51
i ♥ my honda
Global Mod
Global Mod
#52
i ♥ my honda
Global Mod
Global Mod
Re: oil change then check engine light on
#54
just got back from aamco and they gave me a different code now.. P0301 cylinder 1 misfire p0302 cylinder 2 misfire p0303 cylinder 3 misfire p0304 cylinder 4 misfire p0300 ramdon multiple misfire , pending codes p1399 misfire in any cylinder & p0411 air system in correct flow ... . they didnt say anythin about low compression .. let me know
#56
i ♥ my honda
Global Mod
Global Mod
At this point the codes are pointless with low compression. The ECU will not tell you if there is low compression. Do you have your own compression tester? As I said if the compression is still low then you need a leak-down test done to track down your problem. Or you can just rip your motor apart and figure it out yourself. There is nothing more we can tell you with the info we have.
Nukin
04-29-2018 09:36 PM
tacchan
25
04-05-2010 06:37 AM
