Honda S2000 Honda S2000
Act HS1-HDSS clutch, help.....
Old 01-26-2009, 02:12 PM
s2kimportlover's Avatar
Default Act HS1-HDSS clutch, help.....
I am about to buy this clutch kit, but whenever I called the website to buy it, he said that the release and pilot bearing I have to buy it at honda dealership, is that true??
also, do I need to replace my flywheel with a brand new oem flyhwheel???
thanks in advance
Old 01-26-2009, 02:39 PM
AP1_man's Avatar
Default Re: Act HS1-HDSS clutch, help.....
this is true...you don't need a new flywheel. just make sure you examine the flywheel while everything apart.
Old 01-26-2009, 03:04 PM
S2KFTW's Avatar
the ACT kits I've gotten for B-series motors come with everything needed, it would be odd if the more expensive S2000 kits don't the ClutchMasters kit my buddy got came with everything needed.
as far as the flywheel you don't have to replace it, but you should resurface it.
Old 01-26-2009, 03:59 PM
Firstoost's Avatar
They do NOT come with bearings.
DO NOT BUY FROM ACT THEY WILL RAPE YOU ON PRICING
Modacar has one for $465 shipped, hit them up I have a turbo S2000 and have had them do all my work.
Old 01-26-2009, 04:27 PM
powerneedy's Avatar
or clutchnet.com
Old 01-26-2009, 04:44 PM
607motos2k's Avatar
Ive had act clutch in both my s2k and driven my buddies evo and imo act sucks and there customer service is horrible also
Old 01-26-2009, 04:45 PM
607motos2k's Avatar
i got my kit from hardtopguy. He very quick with delivery
Old 01-26-2009, 05:47 PM
S2KFTW's Avatar
yeah, I would never buy another ACT clutch again, I've liked ClutchMasters better for the pedal pressure and engagement in every car I've tried it in.
Old 01-27-2009, 04:22 AM
i my honda
Global Mod
White Smoke's Avatar
I too am not a fan of the ACT clutch's on the S2000.
Old 01-28-2009, 01:43 PM
what clutch do you recommend then?
$500 price range (shipped)
thanks
Old 01-28-2009, 01:45 PM
HondaKyle's Avatar
Why?
Old 01-28-2009, 04:55 PM
S2KFTW's Avatar
thanks
not sure about $500 but the ClutchMasters FX300 is a great clutch. engagement and pedal feel like stock but unlike stock it grips they say it holds up to 110% over stock so you would have to be knocking on 450whp (guessing) before it would start to slip.
Old 01-28-2009, 05:05 PM
S2KFTW's Avatar
I haven't liked ACT in any civic or integra I've been in, maybe for some reason their S2000 is different but I doubt it. for daily drivers their clutches are always a compromise, they'll hold, but at the cost of heavier than needed pedal pressure and a chattery engagement. the clutchmasters is so smooth in comparison it feels just like stock.
on S2KI there's some ACT guys having a problem with thrust washers wearing out prematurely but that's yet to be confirmed for sure. either way it's a problem only common to the ACT guys so far and with their heavy pedal pressure you're pushing and pulling on the crank so that's not surprising to hear.
Old 01-28-2009, 05:41 PM
ArinX's Avatar
why? im loving mine
Old 01-29-2009, 05:33 AM
i my honda
Global Mod
I've never been happy with ACT customer service. I had one in my civic and it had bad chatter and wore out fast. I've always heard from others that there customer service sucks for them as well. Add on the rumors of damage caused by this clutch on the S and you've go me sold... On another brand.
I have no personal experience with them on the S2000.
Old 01-29-2009, 08:34 AM
modacar's Avatar
MY ACT setup in my 300WHP civic was PERFECT, no chatter at all.
XT plate with sprung 6-puck hub, like my Exedy hyper single in the S2K but ACT was MUCH smoother.
Old 01-29-2009, 01:06 PM
S2KFTW's Avatar
the 6 puck, sprung hub, ACT I had in my first CRX ate through my stock flywheel after about 10,000 miles, that sucked
Old 01-29-2009, 01:55 PM
s2kimport's Avatar
I am buying a clutch tomorrow, but I still don't know which one.....
$600 in my price range, including release/pilot bearing....
someone???
Old 01-29-2009, 01:56 PM
HondaKyle's Avatar
you are not aloud to have two user names. FYI
Old 01-29-2009, 02:40 PM
607motos2k's Avatar
on s2ki theres a exedy single w/ flywheel used but 600 bucks is a awesome price. his s/n is jbotstein1
not price range your in but imo exedy clutches are far better then act
civichatcheg6
Transmission & Drivetrain
02-14-2010 10:01 AM
djteggy99
09-23-2008 06:56 PM
jadugartir
11-22-2006 10:07 AM
SlowPokeEg
07-20-2005 06:10 PM
Quick Reply: Act HS1-HDSS clutch, help.....
