Lowering and handling
#26
Re: Lowering and handling
if price is that big of an issue to you, you shouldn't be looking at coilovers....
cheap coilovers is almost never good.
if price is an issue, get springs. i've been running on swift spec r for a year and a half, and that's about 35-40k miles.... my oem shocks are still fine... and i would recommend swift springs to anyone who aren't looking to track their car and just want their car to look better lowered. and, from what it sounds like, you fit that profile.
#28
wtf 2 pages about megan coilovers, i'll settle it. LET'S RACE!!!! WHERE'S THAT INITIAL D MUSIC AND THE TOUGE THAT APPEARS OUT OF NOWHERE ON THE INTERNET?
Oh and excuse my friend, he builds boats with wheels:
#31
We do suspensions for a living and are pretty good at it. Lowering much below say 30mm WILL require changing the roll centers and bumpsteer if you want the car to handle even as good as stock. Further while KW is OK, their dampers are made by a company that specializes in fishing boat shocks called AL-KO and is nowhere near the quality of Moton, AST, KONI, JRZ&c. However, make no mistake we sell KW for certain applications where nothing else is available (5 & 6 series BMWs for example) and it is adequate if overpriced. That stated. I would take KW hands down over Tein, Megan and others in my experience. Spring rates depend upon where you live and how you are going to use the car and anybody recommending without asking some probing questions first is being less than candid with you. We spend a fairly long time with our customers before making judgement recommendations on springs and dampers and we have been doing this for many years with customer data points all over the globe - also beware of people with experience with one car in one location used for one purpose making recommendations for your particular situation unless of course they share all your traits. That is why whenever we have the opportunity, we spec custom stuff instead of these one size fits all kits. Drop me a line if you want to talk suspension or brakes handling whatever.
#32
stock shocks and rates are pretty damn good. you have external reservoir in the shocks and perfect travel. what's your intended usage? or is it just for looks?
#33
If all you really care about is looks, you're okay with Megan's. It's been proven before that most aftermarket suspension lowering mods hurt the suspension geometry more than anything. Unless you spend some real money on top end suspension bits. Some people just want to look good. There's nothing wrong with that. Not everyone is racing to see who can get to the grocery store the fastest.
#36
#37
shit post warrior
There are no inherent handling issues from lowering 30mm or less period, taking away the inherent rear bump/roll steer effects from using OEM toe arms (a totally separate issue and worse on AP1s than 2s but still present). The issues encountered at less than 30mm are issues dealing with crappy dampers and incorrect springrates. For example, a good properly speced GC coilover kit set within 30mm of stock rideheight and speced with sufficient springrates, say 500/400 will improve ride comfort and handling pretty drasticly and at a good price. Where we see issues with such speced kits are with improper install - preloading dampers, uneven ride heights without bar effects (better to cornerweight) and improper damper adjustment - people tend to much higher rebound settings than are optimal (generally people like rebound damping more than car does and tend to use too much until car feels great as it spins out of control from packing down). The GC kit is about as inexpensive as it comes, uses quality KONI yellow dampers (pretty damned good for the price) & Eibach Race Springs (straight rate which is vastly superiour) and makes a huge improvement in every parametre properly speced and installed. Sure there are better available but for street and trackday, it would be tough to beat for the level of skill and limits pushed to by these users.
I will look you up in the near future.
#38
#39
i actually had some brand new megan coilovers. never used them. i traded them and the guy put them on his S and one blew within a month. -just my experience with them
#42
-2,5" IS slammed, as in riding on the bump stops for the most part. It is no wonder they blew, let alone how badly that vehicle must have handled presuming he didn't correct the arms to return roll centers to proper setting. These are pretty crappy dampers and kit to begin with but he never gave them a chance to perform properly.
#43
^ what? the megans just like most new design coilovers lower the car buy lowering the damper into the bottom bracket not by lowering the spring thus making the the shock travel shorter and having it bottom out.
so considering the person using the megans lowered the car correctly he wouldnt be ridding the bump stops. thus their dampers r just pure and utter **** if they blow after a month of street use.
#46
wow..
****ing christ s2000's are turning into such a abused and neglected **** box... ****ing 17 year old kid making 7 bucks an hour drives one and doesn't give two ***** about it.
#47
#48
In any case the particular vehicle was slammed under any definition and any party responsibly selling suspension parts should have advised altering the roll centers for anything below say 35/40mm of drop (much less than even 2") AND provided or recommended appropriately stiffer springs to account for the reduced suspension travel before botoming out be it resulting from hitting coil bind, damper travel or wheel travel and effectively taking the wheel rate to infinity instantaneously which is a very dangerous trait.
#49
