Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda S2000 (https://honda-tech.com/forums/honda-s2000-5/)
-   -   how to clear the maintenance req. (https://honda-tech.com/forums/honda-s2000-5/how-clear-maintenance-req-2377302/)
vinceiscoo Aug 30, 2008 07:43 PM
hi i have a 01 s2000 and i just took it to the shop to get it maintenance but now the maintenance req is on how do you get it to clear???
njn63 Aug 30, 2008 09:52 PM
Re: how to clear the maintenance req. (vinceiscoo)
Using the search button will clear it. https://honda-tech.com/forums/images/smilies/emwink.gif
https://honda-tech.com/zerothread?id=2361299
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">The maintenance light starts blinking every 6k miles or so I believe. At 7.5k it will go solid... This is a reminder to get your 7.5k maintenance done (IE: oil change), that is all. It will NOT tell you when to do a valve adjustment and per your other post, your DO NOT need to get your valves adjusted every 15k!
To reset the light:
- Have key inserted in ignition but in the OFF or LOCKED position.
- Push and hold the trip reset button on the right bottom corner of your gauge cluster.
- Turn key to full ON position and continue holding the button till the light goes off.
If the light is only at the "blinking" stage...
-KEEP HOLDING THE BUTTON FOR ABOUT 30 SECONDS TO BE SURE OF A POSITIVE RESET. Or just be patient and wait till the light is on all the time before doing this.
**Some manuals may be a bit off in that they do not tell you to turn the key to the ON position. The 07-08's are smarter and tell you to change your oil based on actually motor use... There a bit different to reset as well. </TD></TR></TABLE>
vinceiscoo Aug 30, 2008 10:01 PM
Re: how to clear the maintenance req. (njn63)
thanks
megalomaniac001 Sep 1, 2008 09:31 AM
which one is my search button...by the a/c controls maybe??
