Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Zoomer blowing 10A fuse
Old 09-17-2014, 09:55 PM
josh green's Avatar
Default Zoomer blowing 10A fuse
I have a Zoomer here in Japan and one day the push start stopped working. I assumed it was the battery but noticed none if the lights working either. Well I tossed a battery in it bc the old one looked rough and nothing. So a little trouble shooting it was the 10A on top of the positive battery terminal. I change it and it starts a few times and then nothing, fuse is blown again...
Has anyone fixed this problem before? I have searched online but no one has posted what fixed their bikes. Loose ground, bad relay? I really don't know much about them, but am mechanically inclined. Just don't have a lot of time to spend troubleshooting it.
Thanks for any help!
josh green is offline
Old 09-24-2014, 11:36 AM
CXTN's Avatar
Default Re: Zoomer blowing 10A fuse
I would definitely check your ground. Relays are so cheap it might be worth getting a new to swap in.
CXTN is offline
Old 08-30-2015, 04:31 AM
My 2003 ruckus kept blowing fuses...took it to the dealer and they had no idea...after several hundred dollars of other attempted "fixes" it turned out to be the large square blue relay (part of the electrical system - a cheap, easy fix)...just putting this out there in case it helps someone and saves them money and headaches
apewelch is offline
Lantorax
04-18-2018 02:36 PM
ZoomerDude
07-11-2017 10:27 AM
SiCivicHB1993
06-12-2016 09:03 PM
Lastman
11
09-04-2015 04:20 PM
Quick Reply: Zoomer blowing 10A fuse
  • Ask a Question
Question Title:
Description:
