PC20 help!
PC20 help!
ok guys i need help. so i have a 09 ruckus with kn variator 5.5 & 6 weights,posh cdi,leo vance exhaust,poloni belt,white contra spring and Keihin pc20. i am running 38sj, 85mj needle at halfway and mixture screw 2 1/2 out from lock, now my problem is that i cannot run my ruck at all when the choke is all the way open..wtf. as soon as i open it up all the way it just shuts off, like its a switch. i have a wide band, i've tried going as high as a 95mj still shuts off when i open the choke all the way. however when the choke is closed it runs fine. but whats the point of a pc20 if the choke is closed! i need help guys, am i sopose to run it with the choke closed? any help would be great!! thanks!
Re: PC20 help!
Im running a similar set up. Im running a Keihin PE20, with a Leo Vince. I run a 100mj and a 50sj and have the needle clip on one notch down from middle position. I use the choke (open) to start the bike, then close it when its started.
Have you tried adjusting your float position? I had a similar problem that you are having and it was the position of my ploat level.
Float level should be slightly lower then "level" with the carb body.
Hope this helps
Hope this helps
tvrsir
Honda Motorcycles
15
09-14-2009 08:32 AM
d16rice
05-03-2005 03:41 AM
