Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
my 1998 honda elite 50 (DIO)
Old 02-02-2011, 09:05 AM
dumpeddhatchh's Avatar
Default my 1998 honda elite 50 (DIO)
just thought i should share a few pics of my toy,it went from 50cc to 70cc & now its currently a 125cc. bought a stroker kit, cylinder kit. 28mm oko carb & oko intake manifold, tranny has custom gears & just so many more things i forgot to name, but here are some pics
ok so when i 1st got it the rims were yellow so i decided to take her all apart & clean the whole bike and paint the wheels white
then put her back together
then i did some research & found out that i could turn my bike into a 70cc with just a bore & pipping, so i got it
then found a HUGE 28mm oko carb kit & intake manifold !
then put it all together
& also bought a racing CDI box then put it all together
it ran pretty good but i wasnt satisfied with the outcome, so i bought a new race clutch kit front and back ,race springs, & a 125CC stroker kit! a 52.6 mm crank, compared to the oem 41mm crank, and a 52mm bore ! to put the crank on the block had to be sent to the machine shop to be cut & to put the cylnder on aswell since the sleeve was too wide, so i got it all done & removed the oil pump & also got some race gears for the trans
50cc, to 70cc, to 125cc
125cc & 70cc
then put her all back together, RAN LIKE A CHAMP!
then she broke the kick starter gears, comprsion is threw the roof
then decided to open up the boost port on the piston since it didnt match up to the cylinder
then made a new pipe to withstand the 125cc's
the bike wheelies once you hit the gas & the throttle responce is BEAUTIFUL
dumpeddhatchh is offline
Old 02-02-2011, 10:23 AM
Default Re: my 1998 honda elite 50 (DIO)
That would be a cool pit bike ''nice''
Golden Eagle is offline
Old 02-03-2011, 04:17 AM
STR8 to Ignore List
NICE PROGRESS TOP SPEED?
STR8 H8N is offline
Eran
Appearance Build Threads
86
02-12-2019 10:12 PM
1013mm
General Discussion and Debate
09-06-2011 06:18 PM
1013mm
07-08-2011 06:23 AM
CWalsh
Other Make Vehicles
12-27-2010 11:32 AM
1013mm
10
08-18-2010 12:02 PM
Quick Reply: my 1998 honda elite 50 (DIO)
  • Ask a Question
Question Title:
Description:
