Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
1986 Honda Elite 80 Scooter
Old 12-04-2012, 11:11 PM
Default 1986 Honda Elite 80 Scooter
Hey guys,
I have recently acquired a 1986 Honda Elite 80 from a good friend of mine. When I received it, it was not running. I got a new battery, spark plug, fresh gas, and some starter fluid and I was able to fire it up and get her running. After cruising around the neighborhood for maybe 20 minutes she died on me and I had to push her home.
I took apart the gas tank and tried to clean it out (I noticed lots of rust/corrosion because the scooter sat in my friend's garage for so long). I got a new fuel filter and I took apart the carb and cleaned it out as best as I could. I also replaced the electronic choke (I had read online that it was a highly faulty part and I went ahead and replaced it). Ever since I did all of this, I have not been able to get the scooter to maintain an idle or stay alive for more than just a few seconds.
I have messed with the idle adjustment screws as well.
I have tried cleaning the carb several times now (taking it all apart and putting it back together) and it hasn't been significantly dirty. I still haven't been able to get the scooter running properly.
BOTTOM LINE IS: I have a fresh battery in the scooter and I can only get the scooter to fire up with starter fluid and then the engine appears to rev very high for just 2-3 seconds and then it dies and shuts off. I barely have any throttle response (if any at all)
I am unsure what else I should try, any suggestions or ideas??
I just wanna ride
Thanks,
Austin
noobaccord is offline
Old 12-14-2012, 08:14 PM
porkenstein's Avatar
Default Re: 1986 Honda Elite 80 Scooter
I am guessing you still have problem with a jet that is plugged. Did you soak it in carb cleaner.
porkenstein is offline
VFR
08-17-2016 03:38 PM
KevGotti
08-14-2014 08:01 AM
GustaFam7
07-23-2010 12:17 PM
esdrunkcuz562
04-19-2010 03:42 PM
thehatchninja
Honda Motorcycles
06-01-2003 02:34 AM
Quick Reply: 1986 Honda Elite 80 Scooter
  • Ask a Question
Question Title:
Description:
