Will a F20B fit in a 95 prelude?
I an looking at replacing my current non-vtec with a vtec in my 95 prelude. I was wondering if a F20B would fit in the car and what if any modifications would have to be made?
Re: Will a F20B fit in a 95 prelude?
Yes it will convert it to OBD-1 and use your current mounts. Run the P13 ecu until you get a chipped P28. Wire up vtec and have fun. I think thats it. If anymore is needed anyone please add to the list.
Why an F20b?
Its an easy swap. Same as an H22 swap. You might need to swap out your current front motor mount bracket. Use an OBD1 H22 dizzy. Use your harness and fit it to the f20 when its on the ground. youll have to graft 3 wires along the harness. Knock sensor wire, VTEC solenoid wire and VTEC oil pressure switch wire. The F20b's 3 wire IAC wont work with OBD1 management. 2 options, use an H22 upper plenum (it has provision for a 2 wire IAC.) or an adapter plate. Blactrax and Rosko racing carry them.
Again. Why an F20b? It has no torque.
why an f20b?
it's an iron block without the frm, makes it ideal for forged pistons for a turbo setup or a high compression all motor setup.
You can spend the same $$ on an H22 with compatible pistons and it will make more hp and torque. All that FRM slamming is old news.
it has been a while since i've been on. i'm guessing the mahle pistons are actually proven to not be shitty now?
so is the f20b a bad swap? i just bought a 93 prelude and it has an h23 but im looking to upgrade.
or would i be better off doing an h22 head swap?
Daughter not possible
I took out a fine running H22 for the F20B...just because. But anyway, there is a 11 ft.lb difference I think, and YES you actually feel it. But then again I had an 8lb flywheel installed with the F20B, and stock one on the H22, so that could be why it feels different.
1 Post
FRM is quite gay, knowing that it WILL burn oil at some point.
F20b is more rare than the h22a ..if ya want to be different do the f20b..they are fairly cheap now a days as well
The F20b has less torque than your H23. Not good in a heavy prelude.
I did an F20b swap for a customer and the car didnt "pull" as hard as an H22.
Have you considered an H22 or H23 bluetop DOHC VTEC swap?
if the f20b's crank mains are the same size, assuming it's a similar casting to the other f series, i don't see why you couldn't put your h23 crank in it and bore it out to 87mm or more. make yourself an f23b or something.
formerly xmod_supra
The best voted honda of the year (Stickydiljoe) was Big Mikes 92-96 Honda prelude which has a F20b in it. Something to think about.
formerly xmod_supra
^^^^ Ok??? I didnt say it pulls hard or walks people. I just said that the best voted honda has an f20b in. So it must be a good motor. Dont get all ahead of yourself.
i got a full f20b swap for sale for 1200 if youre interested. Was gonna put it in my accord but got other plans now. Email me if you're interested vmachi97@yahoo.com
Ha Ha! Youre using a B16 as a basis of a quick car. You should pick races against D15 4drs. Youll win everytime. The H22 against the F20b, all stock, same car. The H22 walks the F20b anyday.
lol i used to rape b16s and beat but not rape b18s with my f22b1 sohc. but any how, ive had both h22 and now currently f20b, in my 94 accord. gotta tell ya like both but i like the f20b more only cause its different not many people have them unlike h22's where everyone and their brother have one. plus i was able to pick one up for 500 bucks with only 20k on it from jdmenginezone.com depending on where you look you can pay anywhere from 500 to 2500 for just the f20b engine and your more likely to pay more for the h22 cause of supply and demand. its really only more about preference the whole 20hp diff screw it make up for it with a good tune and minor bolt ons.
Why did honda make the F20b in the first place? Wasnt it to increase sub 2 liter production to avoid paying higher taxes? Or something like that.
