Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Prelude (https://honda-tech.com/forums/honda-prelude-4/)
-   -   The "Where Can I get" this thread. (https://honda-tech.com/forums/honda-prelude-4/where-can-i-get-thread-1347266/)
PrecisionH23a Aug 21, 2005 09:44 PM
Everyday I see another "Where can I find" something thread.
This will be the official thread to ask where you can find something. Please respond with answers and I will later sift through the info and make one giant thread of resources for hard to find parts/components.
Let's get this ball rolling https://honda-tech.com/forums/images/smilies/emthup.gif
p.s.
This is NOT a wanted bad thread. Make a post saying "I need XXX, hit me up" and you will be docked points.
This is not also a thread for WHERE CAN I FIND THIS FOR CHEAP.
mgags7 Aug 21, 2005 10:03 PM
Where can you get:
Adapter plate for the sh block to fit a regular midshaft??
Plastic js racing replica intakes
Honda318dx Aug 22, 2005 05:49 AM
Re: (mgags7)
Q) Where to find Balance Shaft Delete Kits?
A) http://www.kaizenspeed.com
The Weather Man Aug 22, 2005 09:58 AM
Q) Where can I find block guards?
A) http://www.honda-performance.com
rockna92quelude Aug 22, 2005 12:51 PM
Re: (mgags7)
i had the same problem and made a adapter bracket to bolt the shaft to the sh block from a pice of 1/4 plate steel measured like 4 by5 and measured the holes in the shaft bracket and then tapped those holes then drill the holes is the plate for the block... insert shaft to trans and then slide plate in to be bolted into place.. i was told that it would never work but its been in there for almost 15000 miles and ALOT of dragstrip time and no problems yet...
Shahigabothin Aug 22, 2005 01:32 PM
Re: (rockna92quelude)
Does anyone kno where i can get this front lip. I cant seem to find it any where, if someone knows where i can get it please post a link.
http://memimage.cardomain.net/member...96_20_full.jpg
Modified by Shahigabothin at 3:29 PM 8/22/2005
Geeq Aug 22, 2005 06:54 PM
Re: The "Where Can I get" this thread. (PrecisionH23a)
Where can I get....Or do they make?
The mounts for your Stock or OEM style hoods that can be lifted where the hood meets the windshield.
I've seen it Searching for Pics of cars. It's a JDM style that you don't see here in the US...so I've heard. It creates a sort of Cowl induction by lifting the hood up an inch or two still using your stock hood.
Does anyone klnow if there are any Kits or is it just custom fabrication???
upallnite Aug 23, 2005 12:44 AM
Re: The "Where Can I get" this thread. (Geeq)
I think I have seen what you are talking about. The car I saw with it just did it his self with longer bolts and washers as spacers. You can't raise it much if you want the latch to still work right.
LudeyKrus Aug 24, 2005 11:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Geeq &raquo;</TD></TR><TR><TD CLASS="quote">Where can I get....Or do they make?
Does anyone klnow if there are any Kits or is it just custom fabrication???</TD></TR></TABLE>
Ace Hardware/Fastenal. Get longer bolts and a handful of washers and go to town.
Shakes Aug 25, 2005 03:14 PM
JDM? if anything its SoCalDM.
its a metal dowel cut about 3/4 of an inch or however far you want. however be careful, 1 - it looks like shit on ludes, 2 - its easy to break a window (done it myself), however it does let tons of heat out of the engine bay.
IAluder95 Aug 26, 2005 07:50 AM
where can i get a Kit to use a B series Tranny?
matix Aug 26, 2005 09:05 AM
Re: (IAluder95)
Q) Were can I get a adapter plate to mount a D-series tranny on a h22?
A) http://www.bisimoto.com/wst_page10.html
PreludeWhore Aug 26, 2005 03:52 PM
Okay here it goes...flame suit on...WHO makes the side skirt? Where can I get them from..etc??? Thanks in advance!
https://i6.photobucket.com/albums/y2...Mugensides.jpg
DF
LudEnthusiast Aug 26, 2005 09:36 PM
Looks like a VIS Mugen sideskirt to me.
jg86hawk Aug 27, 2005 04:47 PM
Re: (LudEnthusiast)
The picture you posted is named "mugensides"
PreludeWhore Aug 27, 2005 10:42 PM
I'm hosting this picture (I got somewhere here or PO.com) I don't know who makes it, but it sure doesn't look like the real mugen.
clemsoncb7 Aug 28, 2005 08:01 AM
Re: (PreludeWhore)
(Q)where can I find a deck plate/torque plate for honing?
(A)www.f22parts.com
(Q)where can I find JDM fogs, headlights, corners, etc.?
(A)www.passwordjdm.com
(Q)Where can I get a beef and bean burrito?
(A) Taco Bell, duh
Jordans95si Aug 28, 2005 10:09 AM
Re: (maxvtec7500)
where can i get some ngk spark plug wires and plugs for a good price
Paul H22A4 Aug 28, 2005 08:07 PM
NGK Spark Plugs and Wires
http://www.importrp.com/home.php
The Birdman Aug 29, 2005 01:03 PM
where can you find some polyurethane aftermarket motor mounts?
Paul H22A4 Aug 29, 2005 04:38 PM
Re: The "Where Can I get" this thread. (jd3jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jd3jdm &raquo;</TD></TR><TR><TD CLASS="quote">where can you find some polyurethane aftermarket motor mounts?</TD></TR></TABLE>
inlinefour.com
The Birdman Aug 29, 2005 05:48 PM
Re: The "Where Can I get" this thread. (Paul H22A4)
If you are talking about the energy suspension ones, they aren't mounts, just inserts. I'm looking for the whole mount.
Paul H22A4 Aug 31, 2005 07:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jd3jdm &raquo;</TD></TR><TR><TD CLASS="quote">If you are talking about the energy suspension ones, they aren't mounts, just inserts. I'm looking for the whole mount.</TD></TR></TABLE>
They sell both there. Mounts and Inserts
http://www.enjoracing.com/engine_mounts_swap.html has some.
getbig Aug 31, 2005 07:09 PM
Q) Carbon Fiber Cooling Shroud (Above the radiator)?
dand39 Aug 31, 2005 07:40 PM
Where can I find an intake chamber for a 4th Gen w/ H22?... provided there is one...
