acl bearing question
Old 11-13-2010, 08:14 PM
red_99_lude's Avatar
Icon2 acl bearing question
if i run the acl bearings will i need to have my crank turned and the rods aswell for a spun rod bearing. is the outside diameter the same on every rod or do they vary. or is it just the inside that is different? also i drive a 1999 honda prelude jdm h22a motor
Old 11-13-2010, 09:26 PM
InvaderTrax's Avatar
Default Re: acl bearing question
Someone has a lot of searching to do
Old 11-16-2010, 12:13 PM
so nobody knows?
Old 11-16-2010, 04:35 PM
mafia's Avatar
Make sure you get the right bearing size for each rod and main bearings. You might have to take it to a shop to have the grind or resurface the crank to make it smooth and then measure the clearance you will have.
just my .02
vteczone
08-06-2008 04:04 PM
vteczone
08-06-2008 10:51 AM
TurboKneeGrow
03-18-2008 02:58 PM
sixtodc4
01-20-2008 09:33 AM
D.Dappa
07-16-2007 01:57 PM
Quick Reply: acl bearing question
