What are the signs of a bad ignition coil/distributor??
Hey all,
I was curious to find out what some tell-tale signs are for a coil and distributor going bad?? I'm troubleshooting a major bogging problem I am having with another car I have. Thanks, Andy |
Re: What are the signs of a bad ignition coil/distributor?? (AndyD)
i had a big problem... my rpm's were jumping after 3,000. Well on the speed amitor they were jumping but car was fine. then car started to jurk alot (when driving die's, then starts cuz driving) and all that problem was in the distributor. After i changed that car runs perfect! https://honda-tech.com/forums/images/smilies/emwink.gif
Re: What are the signs of a bad ignition coil/distributor?? (mafia)
Did you change the whole Distributor, or just the housing?
Meaning, did you get the distributor with the ignitor, coil, already inside or did you already have these parts and just replace the distributor housing? Hope you can understand my question. I am boggled by my no-start problem as well and would like to get to the bottom of it. Tired of buying parts! LOL! |
Re: What are the signs of a bad ignition coil/distributor?? (Ace of Spades)
i changed the whoul peace.
im having the same problem. would it be possible that it was just your coil?
misfire all the way through your rpm range.
Re: What are the signs of a bad ignition coil/distributor?? (PrecisionH23a)
i have a coil from a 5th gen if anyone here needs one https://honda-tech.com/forums/images/smilies/emthup.gif
Re: What are the signs of a bad ignition coil/distributor?? (OneLude2envy)
I was having severe bogging issues with my car as well and it came down to the distributor. I checked on the parts I needed and it was about $40 more for a brand new distributor through distributor king. Now no problems.
Just a tip, I had a misfire on my d16z6 and It was a valve that needed adjusting just a tip.
My coil might be bad as well Because my car Boggs down Then shuts down after a few mins I'm going to change it out And let you guys know what happens. |
Originally Posted by Mr learns alot
(Post 50113894)
Originally Posted by Mykizism
(Post 50114779)
Good to know, but previous posts are dated 2006 and back. So its been about 8 or 9 years since. Not sure if those guys are still active or remember that far back. lol
So neat to see so many older members still here!!! :-) 2002 members!! |
Originally Posted by AndyD
(Post 50116205)
LOL I haven't been active for a while. I came back and I see this thread.
I'm still new only been on about a year, but still these posts are realy usefull. We never know everything, but together we can do anything. This old post helped me find out that I need a new dizzy for my D16Z6 Vtec motor so thanks to all of you who to make this place great!
