Type - S pistons/ Bottom end question
For now I have a stock bottom end, But I was looking at getting some Type - S pistons. I dont exactly remember everything that people have said, but it seems to me that if you get certain types of rods then you can use OEM pistons......is this even logical?
Any suggestions for good H22 Rod/piston setup? (without resleaving)
Thanks, Mark
Thanks, Mark
Re: Type - S pistons/ Bottom end question (SlvrEj6Dx)
Type-S pistons you use stock rods....but you could get aftermarket rods...makes no difference in fitment, just the aftermarket will be stronger, but the stockers are fine for N/A near stock rev lmits
Re: Type - S pistons/ Bottom end question (96SR-V)
I think the stock rods have to be modded to accept floating wrist pins....?I could be wrong....
I think that is only done to the OBDI motors ie 93-96. The 97+ H22A's already use this and thus is not needed
Re: Type - S pistons/ Bottom end question (Fly1865)
So if I went with aftermarket rods then I could use the Type - S pistons without going through a bunch of crap? Hmm.....I think its time to un-swap my car....and build the sh*t out of my h22......
I hate getting beat by b16 powered cars LOL
What does everyone think about the Skunk2 Stage 2's for a N/A Azz kicker?
Mark
Mark
hey mark..
havent seen u on in a while....
hmmm... i've only known one of my friends to have the skunk 2 stage 2 cams, but they were on a civic si. he liked em... expected a lil more from them.. but he got 161 hp to the wheels with i/h/e/vafc/skunk2cams/skunk2gears. i dont know where the vafc or the cam gears were set to..but.. thats it.. 161...
hey what ecu are u running now?
Re: Type - S pistons/ Bottom end question (hondaZvic)
Got me a 96 P13 (obd II)
but I payed out the @$$ for it......
I did finally get my car to the track...and I was surprized/disapointed
I only ran 15.1 @ 91 (my 60' was 2.48) and that was on 17's.......so with slicks/drag radials I think I can exspect mid-low 14's (completely stock-open header)
Mark
[Modified by SlvrEj6Dx, 12:04 AM 11/16/2002]
Mark
Re: Type - S pistons/ Bottom end question (racerx)
you should be faster than that dude... i run mid 14's in my heavy *** prelude on street tires
I need to check my cam timing/ign. timing and compression....but I work on cars all day...so when I get home I just want to sit on my a$$
Mark
[Modified by SlvrEj6Dx, 8:19 PM 11/16/2002]
Floating wrist pins ar exactly that. Most other cars use pins that are pressed into the piston. Ours have c-clips that hold the pins in place. Its done that way to reduce fricion a little between the rid and the piston via the wrist pin.
